USB EZ-PD™ Type-C Forum Discussions
MaKe_4459911
5 questions asked 10 sign-ins 5 replies posted
I need to communicate with a TI PD chip that uses TI's PDIO alternate mode.  Has anyone attempted this?  I'm using the CCG3 as a DRP.
Sananya_14
Moderator 750 replies posted 500 replies posted 250 solutions authored
You could check if the port is in a UFP role using the dpm_get_info() API and reading dpm_stat->cur_port_type before handling the VDMs. If you need to send any VDMs to the UFP, you could use the dpm_pd_command() API after checking if the vdm task manager is idle.
Example usage:
if (is_vdm_task_idle(port))
     cmd_buf.cmd_sop = SOP;
     cmd_buf.cmd_do[0] = /* add your custom data */;
     cmd_buf.no_of_cmd_do = 1;
     cmd_buf.timeout = 100;
     while (dpm_pd_command(port, DPM_CMD_SEND_VDM, &cmd_buf, pd_command_cb) != CCG_STAT_SUCCESS)
In the pd_command_cb(), you could evaluate the response for the VDM and perform necessary operations.
Sananya
Sananya_14
Please let us know if you have CCG3 configured as a UFP or DFP? If it is a UFP, you could add the TI SVID under the configuration and add the VDM handling for the GPIOs for PDIO mode under eval_vdm() function in vdm.c file.
Please refer to the Host SDK User Guide for detailed explanation of the VDM handling in the firmware.
Sananya
MaKe_4459911
We're setup as a DRP but need these Vendor Defined Messages working while operating as an UFP.
Sananya_14
Example usage:
Sananya
