NoAr_1540581
250 sign-ins 100 replies posted 100 sign-ins
Hello
They plan to write the HEX file to the internal Flash of CY7C65219-40LQXI using ROM Writer.
But, Is there a Document like “CYPD_Programming_Specification” for the CCGx series?
Best Regards
Arai
Sananya_14
Hello Arai-san,
DMC (CY7C65219-40LQXI) also follows the same SWD programming procedure as the DMC controller in HX3PD so the programming specification that can be followed is- https://www.cypress.com/file/479596/download
Please note that the Silicon ID will be different and can be obtained from the DMC datasheet.
Sananya
Sananya_14
Hello Arai-san,
Sananya
Hello Sananya san
Q)
Based on the document, I think it is possible to program HEX files to the internal Flash of CY7C65219  using the SWD pins, and it is possible for a PSoC programmer to program HEX file using Miniprog3, is that correct?
Or is it necessary for the user to create a programming FW according to "4. Programming Algorithm" from an external CPU via the SWD pin?
Best Regards
Arai
Hello Arai-san,
Yes, that is correct. The .hex file generated by PSoC Creator can be directly programmed using MiniProg3 on the SWD pins through PSoC Programmer. You could also refer to Page 9 of the DMC datasheet for the same description- https://www.cypress.com/file/402646/download
Sananya
