Live Webinar: USB-C adoption. Simple & Cost-efficient solutions | April 18th @9am or 5pm CEST. Register now !
MaLi_3529141
25 replies posted 25 sign-ins 10 replies posted
Dear,
I use the dock example code of CYPD4236 to modify.
Before doing PR_Swap, I use the following method to change the required Source_PDO:
In this way, I can switch to the PDO I need.
But I encountered a problem:
When I set it to 20V 4.5A, it is still 20V 3.25A as observed from the CC Analyzer.
I want to ask:
What changes do I need to make to charge 20V 4.5A after PR_Swap?
Best Regards
MaLi_3529141
Hi Abhilash P,
After I modified the DEFAULT_CBL_CAP, this problem was solved.
Thank you for your assistance.
Manu
Abhilash_P
50 likes received 500 replies posted 250 solutions authored
    As per the current in analyzer utility, we can see that it is increasing above 3A but not reaching 4.5A. Please let me know if you have used an EMCA cable in your application.
And can you please let me know the conditions before the PR_SWAP incident?
Can the sink handle 4.5A?
If it is possible can you please share the CC logs?
Abhilash P
Hi Abhilash P,
1. My sink can handle 20V 4.5A. (refer to the accessory Adaptor 90W charge.ccgx3)
2. In my Code, first change the Source to 20V 4.5A, then after PR_Swap, it is still 20V 3.25A CC Log. In this case, I used EMCA cable.(refer to attachment 4236_PR_Swap.ccgx3)
3. In addition, If I don't use EMCA cable, can I reach 20V 4.5A Power source? How to modify the code?
Manu
Hi Abhilash P,
Is there a current upper limit for changing SRC_PDO using dpm_update_src_cap()?
How can I achieve SRC_PDO 20V/4.5A?
Manu
MaLi_3529141
Hi Abhilash P,
Manu
