TraveoII CYT2B97CA WorkFlash
yuejin
Hi!
I have a  problem。
In M4 Core ,I use Cy_Flash_BlankCheck to check the address,the function return CY_FLASH_DRV_FLASH_NOT_ERASED。But I read the address,it will go the hardfault。
code:
uint32_t  ReadWFlashU32 (uint32_t add)
    uint32_t ret;
    cy_stc_flash_blankcheck_config_t blankCheckConfig;
   blankCheckConfig.addrToBeChecked = (uint32_t*)add;
   blankCheckConfig.numOfWordsToBeChecked = 0x1u;
   if ( CY_FLASH_DRV_FLASH_NOT_ERASED == Cy_Flash_BlankCheck(NULL, &blankCheckConfig,    CY_FLASH_DRIVER_BLOCKING))
        ret = (*(uint32_t *)add);
   else
        ret = 0x00000000uL;
    return (ret);
