TRAVEO™ T2G Forum Discussions
MF
what is the difference between those three boards, I Understand that all of them are socketed body evaluation board.
so
1- Are the evaluation boards themselves compatible and the changes are related only to the chip(Microcontroller) it self which could be replaced?
2-what are the differences between the microcontrollers if any ?
3-why I can't find a link to buy the "CYTVII-B-E-2M-176-CPU"?
4-for each one of the below items does they come with their corresponding  microcontroller or it is being purchased separately?
AS_36
100 likes received 500 replies posted 250 solutions authored
Hi @MF
Please see our response to your questions below -
What is the difference between those three boards (CYTVII-B-E-176-SO, CYTVII-B-E-1M-176-CPU and  CYTVII-B-E-2M-176-CPU)
CYTVII-B-E-176-SO : It is the socketed evaluation board for TVII Body Entry family. It has a 176 pin socket that supports the TVII CYT2B7 series Flash 1M 176pin LQFP Device. This information is present in the landing page of the board.
CYTVII-B-E-1M-176-CPU : It is a non socketed evaluation board for TVII Body Entry family. It has the Traveo II CYT2B7 series Flash 1M 176pin LQFP Device soldered directly on to the PCB. Product landing page.
>> Functionally, the CYTVII-B-E-1M-176-CPU and CYTVII-B-E-176-SO boards are identical, except that the device can be easily replaced in the latter. This information is given in evaluation board user guide on page 5.
CYTVII-B-E-2M-176-CPU : This is also a non socketed evaluation board for TVII Body Entry family. It comes with a Traveo II CYT2B9 series Flash 2M 176pin LQFP Device soldered on it. Landing page.
1- Are the evaluation boards themselves compatible and the changes are related only to the chip(Microcontroller) it self which could be replaced? Functionally, the CYTVII-B-E-1M-176-CPU and CYTVII-B-E-176-SO boards are identical, except that the device can be easily replaced in the latter. This information is given in evaluation board user guide on page 5.
2-what are the differences between the microcontrollers if any ? CYTVII-B-E-1M-176-CPU and CYTVII-B-E-176-SO both have the CYT2B7 chip. CYTVII-B-E-2M-176-CPU has CYT2B9 chip. You can get the datasheet for both these devices from here. (Go to 'Products' tab)
3-why I can't find a link to buy the "CYTVII-B-E-2M-176-CPU"? Kindly contact your local sales office in this regard. You can find the details of sales offices here.
4-for each one of the below items does they come with their corresponding  microcontroller or it is being purchased separately? All boards (socketed/non socketed) come with a microcontroller already in place.
Regards.
AS_36
Hi @MF
Regards.
MF
Thanks for your reply,
Having said that, if we bought the "CYTVII-B-E-176-SO" is it possible to purchase  "CYT2B9 series flash 2M 176Pin" controller later and use it on the same board, would it be compatible ?
AS_36
Hi @MF
Please see the highlighted section in the screenshot below -
Does this answer your question?
Regards.
