traveoii transplant Freertos code
sangbiao123
First solution authored 10 sign-ins 5 questions asked
dear infineon engineer. i want to add the freertos code to the  TVII_Sample_Driver_Library_7.0.0 or lower version,
is there any manual to refer to. or traveoii series board support to do so?   thanks a lot!
Janine_Y
50 solutions authored 10 likes received 25 solutions authored
Hi sangbiao123,
The new version of SDL has an example code for freertos:
\src\examples\rtos
The download link of newer version of SDL is as follows:
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.traveoiisampledriverlibrary
It is recommended to refer to and use the new version of SDL as it will fix bugs and add some features.
Janine
Janine_Y
Hi sangbiao123,
\src\examples\rtos
Janine
