Bhagyalakshmi
10 sign-ins First like given 5 sign-ins
how do we calculatre the memory consumption while from the time CAN message received, stored and sent it on the gateway.
for example
Memory consumption details (of RAM, NVM if used) while from the time CAN message received, stored and sent to spi
please provide some de
SDESA
50 solutions authored 100 replies posted 100 sign-ins
Hi @Bhagyalakshmi ,
>> The RX and TX handlers carry out all message handling operations. The RX handler controls the filtering of received messages for acceptance, the transfer of messages from the CAN core to a message RAM, and the status of received messages. The TX handler provides transmit status information and moves transmit messages from the message RAM to the CAN core.
>> overall message RAM size can be different for each Traveo device. Please refer device specific datasheet for message RAM size
>> The size of your data frame, which primarily depends on user application, determines how much memory is used during CAN operation.
Please refer the application link
Please refer the section from Arch TRM  :
23.1 Overview
23.4 Message RAM
Shubham
SDESA
Hi @Bhagyalakshmi ,
Could you please mentioned Traveo T2G board you are using in your application?
Shubham
hi its a 64 pin package traveo board
hi its a 64 pin package CYT2B9
SDESA
Hi @Bhagyalakshmi ,
23.1 Overview
23.4 Message RAM
Shubham
