Viku_4403276
I am working on CYT4B controller. I need to configure UART driver for my project. I have an example driver(given by cypress).
I have few doubts :
  1. My driver is working fine on low level(directly writing and reading from FIFO register) but, it is not working  with high level API where transmit and receive happens with help of interrupt. Basically i am not able to understand the ISR configuration.Cy_SysInt_SetSystemIrqVector(stc_sysint_irq_cfg_uart.sysIntSrc, Scb_UART_IntrISR);
  2.   While going through the code i understood that, in high level tx/rx is event based. So, does it need some os configuration?
Thanks in Advance
HongyanW_86
100 solutions authored 100 replies posted 50 solutions authored
This topic is not suitable to be discussed here in this community. Please kindly get in touch with your Cypress contact window for help.
Amy
HongyanW_86
Amy
chch_4421126
5 sign-ins 5 replies posted First reply posted
Because old project development needs to be continued.
