hello,
I am trying to generate hex and elf file with cmakelists for blink led project.
I am also using IAR files from the traveo SDL folder tviibe1m.
Unfortunately, I am not able to create the hex and elf even the compilation is without errors.
Would appreciate if you can review my project.
thanks,
Hi Meriam,
I would suggest you to refer the latest SDL 7.5 for CMake support and you can refer it for your reference. Download and install SDL, then go through the "CMake_Readme.md" file (path -->> T2G_Sample_Driver_Library_7.5.0\cmake) and "CMakeLists" file (path -->> T2G_Sample_Driver_Library_7.5.0) for configuration.
Try the mentioned steps as per "CMake_Readme.md" file. Hoping this will help you and solve your query.
Also for toolchain support, Please refer SDL "Readme" file(path -->> T2G_Sample_Driver_Library_7.5.0).
Below is the snippet of same :
Link for latest SDL : https://softwaretools.infineon.com/tools/com.ifx.tb.tool.traveoiisampledriverlibraryutil?utm_source=...
Thank you.
Apurva
Can you please let us know which compiler and SDL version you are using ?
Thank you.
Hello Kumar,
I am using SDL 7.1.0 and (GNU Arm Embedded Toolchain 10-2020-q4-major) 10.2.1
thank you
Hi Meriam,
Thank you.
Apurva
Thank you so much for your response.
Would it work if I change the compiler from IAR to arm gnu ?
Hi Meriam,
We have not tested on arm-gnu, So we are not sure about the output behavior. you can try this.
But currently we don't have any documentation regarding how to add a new compiler support for CMAKE.
Also please refer "Known Issues" and "Feature list" from the "CMake_Readme.md" file (path -->> T2G_Sample_Driver_Library_7.5.0\cmake).
We have only tested on GHS/IAR and Windriver DIAB (only on TVII_BE-1M devices) compilers and CMAKE support for these compilers are present in latest SDL 7.5.0 also.
Thank you.
Apurva
