hello everyone,
I am an intern at an automotive company and i have to work with traveo ii, for the first time.
i think there isn't enough documentation about it on the internet or sample codes.
Could anyone, please, send me a sample code for a blinking led using traveo?
is the iar embedded workbench the IDE for traveo ii?
please recommend me any basic information.
thanks
Hi meri,
1) Refer this AppNote for Traveo-II getting started-
2) There is a Sample Driver Library (SDL) which is provided by us (it's intended for testing/evaluation purpose only, and not production purpose as it does not qualify to automotive standard-the MCAL should be purchased for that!). The SDL is easy to get started- and has many test examples including blinking LED. It supports both GreenHills Multi IDE, and IAR Embedded workbench IDE. You may refer this link for download-
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.traveoiisampledriverlibrary
3) Kindly note for the latest version of SDL, and all the latest documentation (including AppNotes, datasheets, Technical Reference Manuals) - we would suggest you to go to MyICP platform. Check with your colleagues if someone has access to MyICP- if not, you may register with your official email id on MyInfineon and request access for Traveo documentation-
You can also refer to the Traveo T2G product page for documentation (but only public documents is available here), and you still need to sign in on MyInfineon. For example for Traveo T2G - CYT2B9 product refer below-
Ashish
Hi meri,
Ashish
