Sentinel
First solution authored 5 sign-ins First reply posted
When I read data from the Work Flash after erasing it i read random Data, is that normal?
Ashish
25 likes received 50 solutions authored 100 replies posted
Yes, what you observe is normal. You can only read from WorkFlash location, after it is programmed. This is by design. Reading from erased location is not possible (so if you try with debugger- it will result it random data). Normal flow is- erase then program then read. Below is screenshot from architecture TRM.
Ashish
Ashish
Ashish
