KaKo_4074056
Level 4
Level 4
Distributor - Marubun (Japan)
First like given First solution authored 25 replies posted
Could you explain in detail why we can't use MiniProg4 for mass production? It's inexpensive and easy-to-use programming tool for T2G and PSoC.
AN220118: Getting started with TRAVEO™ T2G family MCUs
3.7 Flash Programming Tools
Infineon MiniProg3/4 programmer is for development purposes. For mass production purposes, JTAG programmer from a third-party is suitable.
RyanZhao
250 sign-ins First question asked 750 replies posted
Hi KaKo_4074056-san,
Thank you for using Infineon Community.
1. From the beginning of the product definition of MiniProg-3/4, it is not defined/developed for mass production environment. Besides SWD programming/Debugging, at same time, SPI/UART/I2C bridge functions are integrated, which is more suitable for debugging usage.
2. There is no specific extension board for mass production to replace target devices quickly when using MiniProg-3/4.
3.   Generally, a mass production may have the capability to program target devices in parallel/burst mode; for example, programming 4 or more target devices every cycle; but MiniProg-3/4 doesn't support such kind of feature.
So, for mass production purposes, JTAG programmer from a third-party is suitable.
Ryan
RyanZhao
Ryan
KaKo_4074056
Level 4
Level 4
Hi Ryan-san,
I got it. Thank you so much.
