WCO timeout issue with RTC
k_a
I am facing one issue regarding Timeout while configuring the RTC with WCO.
I am calling Cy_SysClk_WcoEnable(100000ul) function to enable WCO but unfortunately timeout response is coming.
Imam_M
50 replies posted 10 likes received 10 solutions authored
Hi @k_a,
Seems like your Cy_SysClk_WcoEnable is reaching timeout because the WCO_OK bit isn't transitioned as shown in the snippet code below.
Then after checking the provided schematic, your WCO implementation is not correct. Kindly check one of our application notes AN220270 Hardware Design Guide for Traveo T2G Family as shown in the following image.
I hope this answers your query. Thank you.
Imam_M
Hi @k_a ,
Cy_SysClk_WcoEnable API returns CY_SYSCLK_TIMEOUT when the clock is not present. Could you confirm the clock you're using? Thank you.
k_a
Hello @Imam_M ,
We are using external crystal and it is connected to the wco_in and Wco_out pins,
This shall reflect into the following modules
Port - > to configure the 2 pins as gpio the one which is wco_in as input and the one which is wco_out as output
Mcu-> to check that the wco is enable and it configuration as mentioned below
 if there anything missing which shall cause this issue??
Imam_M
Hi @k_a,
