Venkatesh
5 replies posted 25 sign-ins 10 questions asked
Hi ,
Is there any link to the document.
Traveo II body high MCU programming specifications document.
Reza_A
25 solutions authored 10 likes given 50 replies posted
Hi Venkatesh,
Kindly find the T2G MCU Programming Specifications document in the MyICP portal under the Programming Specs folder.
In case you don't have access to MyICP portal, kindly go through the MyICP registration process as described in the following link:
https://www.infineon.com/cms/en/product/microcontroller/#!details
I hope this helps.
Thank you.
Reza Andriady
Reza_A
Hi Venkatesh,
I hope this helps.
Thank you.
Reza Andriady
HI @Reza_A ,
I couldn't see the T2G MCU Programming Specifications in the MyICP portal.
If possible could you share the link to the document.
Reza_A
Hi @Venkatesh,
Kindly find the Programing Specification document by the following path:
Traveo II -> Traveo II Body -> Programming Specs
I hope this helps.
Thank you.
Best regards.
