Traveo 2 Instrument Cluster
VivekPatel
First like given First reply posted First question asked
My name is Vivek I am working on Custom bootloader activity for my one of the client on Traveo 2 microcontroller,
I need help on below topics,
  • Please suggest evolution boards from Traveo 2 - instrument cluster family,
  • Is Infineon is providing any code configurator like PSOC studio for Traveo 2 series,
Vivek
Imam_M
50 replies posted 10 likes received 10 solutions authored
Hi @VivekPatel,
Kindly you can check on this KIT_T2G_C_2D-4M for Traveo T2G Cluster Evaluation Board. That board is based on CYT3DL with on-board Miniprog4.  I also suggest you to use our Evaluation Board Finder if you're looking for evaluation boards from our products.
For code configurator on Traveo II, unfortunately we don't have any configurator-code. But I suggest you to take a look Autosar MCAL which is support for Traveo II family products.
I hope this helps.
Thank you.
Imam_M
Hi @VivekPatel,
I hope this helps.
Thank you.
VivekPatel
Hello @Imam_M ,
Thanks for quick response,
I am new to Autosar can you suggest me where should I find Autosar MCAL ?
Secondly, I need port Non-Autosar based bootloader  from Traveo 1 - Traveo -2 can you suggest me any application note or any other resources that might help.
Imam_M
Hi @VivekPatel ,
Autosar MCAL is a licensed software and if you're interested in it, you can contact our sales representative and they will guide you about that.
In the meantime, if you're looking for a driver to work, I would like to suggest you check the Sample Driver Library (SDL) for Traveo II Products Family. Here's the link for SDL. But remember, this SDL is not recommended for production purposes.
For bootloader resources, you can check on this bootloader application notes.
I hope this helps.
Thank you.
