lucas_wang
Distributor - Yuban(GC)
5 replies posted 10 questions asked 5 questions asked
The customer's current application is Tilting three wheel, with three brushless motors, each with a power of approximately 1kw. they are using three independent MCUs and drivers, and looking for a more integrated solution to save costs. and need to use the MCUs of the car specifications. Do we have a suitable recommendation for Aurix and Travo II?
Reza_A
250 sign-ins 50 likes received 50 solutions authored
Hi @lucas_wang
For motor control please check the following webpages for reference design. However, please note that the below is for your reference and kindly evaluate based on your requirements.
KIT_A2G_TC387_MOTORCTR
MULTI MOTOR EVALKIT with TRAVEO™ T2G CYT2B7
Please check the schematic and in the User Manual tab, and the example code in the Design Support -> Embedded Software tab.
Thanks and best regards.
Reza_A
Hi @lucas_wang,
Please allow me to refer you to the product webpage for Traveo II and Aurix below:
32-bit TRAVEO™ T2G Arm® Cortex® Microcontroller
32-bit TriCore™ AURIX™– TC3xx
Kindly check the above webpages and please evaluate based on your specific requirements.
You can also find the Technical Reference Manual for product families and the available example boards.
Thanks and Best Regards.
lucas_wang
hi   :
     thanks for your replay.
    What I want to know is  which chip  has a mature solution?  Can you provide a reference design!
Reza_A
Hi @lucas_wang
