The same block size Work Flash and Code Flash read, erase, and write time.
tony
First solution authored First like received 5 questions asked
The chip I am currently using is CYT2B75BADQ0AZEGS. Now I want to know the difference in the time it takes to read, erase, and write to Work Flash and Code Flash of the same size. I consulted the data sheet for the chip. But only find above the instructions for the time it takes to chip erase and write. I know the chip has two cores. Different kernels access Flash in different ways.
I would like to ask you some questions:
(1) I want to know the difference in the time it takes to read, erase, and write to Work Flash and Code Flash of the same size. (2)I also want to know what the assembly Code looks like when erasing, writing, and reading Work Flash and Code Flash.
tony
Hi Jimmy_L,
Thank you for the response.
SDL T2G_Sample_Driver_Library_8.0.0\tviibe1m\src\examples\flash
Where can I download the file in this path?
Jimmy_L
250 replies posted 250 sign-ins 50 solutions authored
Hi Tony,
1. we have sample code for the operations of code flash and work flash in SDL T2G_Sample_Driver_Library_8.0.0\tviibe1m\src\examples\flash, you can check the difference.
2. we only provide the API function to customer.
tony
Hi Jimmy_L,
Jimmy_L
Hi Tony,
you can download the SDL installation file on MyICP sdl_additional_code_examples_v8.0.0_w ex_control txt
In case you don't have access to MyICP portal, kindly go through the MyICP registration process as described in the following link:
https://www.infineon.com/cms/en/product/microcontroller/#!details
