Hello ereryone, I want to install T2G SDL 7.4.0. Can anyone provide the download link of T2G SDL 7.4.0. Thank you very much!
TRAVEO™ T2G
I checked-it can be shared- but the size is very large (~500mb) so I can't attach here. Can you try to access it via MyICP (you may need to register and get access for Traveo-T2G first)? Check in "Traveo II Body"-> "Firmware"-> "SDL and MCAL presentation archive" folder- there is SDL7.4 setup.
Ashish
Kindly use latest T2G SDL (it's 7.5.0 as of now) , you can download from here-
Ashish
Hi,Ashish, Thanks for your answer, but i need the version 7.4.0 for EB Tresos to gerate mcal code, Because the compilation environment provided by FAE is based on version 7.4.0, I wonder if you can provide it here.
I would request you to directly check with FAE to provide that SDL 7.4 setup file (as it's not available publicly, I can't share it here).
Ashish
Ashish
