lokesh0806
Hi, We are getting the SPI status busy API "Driver_SPI.GetStatus(SpiDrvDSRC);"for infinite loop, while we are sending command. This is sporadic issue and we are not identifying the root cause of this issue. Please help to resolve this issue. Thanks
Shubham_D
50 solutions authored 100 replies posted 100 sign-ins
Hi @lokesh0806 ,
To conduct a thorough analysis, I kindly request for additional information.
Could you please provide me with the specific type of T2G device you are currently using, as well as the version of SDL driver you have installed?
Once I receive this information, I will test it within the same environment.
Shubham
lokesh0806
Hi Shubham,
We are using Traveo II - CYT2B94CAS QFP80.
SPI is connected with 2 slaves Accelerometer  and RF chip.
We configured auto select slave and checking  SPI status API "Driver_SPI.GetStatus(SpiDrvDSRC);, If it is free Master can send data to slave.
Lokesh
Shubham_D
Hi @lokesh0806 ,
Could kindly confirm whether you are using a custom SPI driver or an SDL based SPI driver? I'm having trouble locating a particular function in SDL and I would appreciate any insights you can provide on this API/function.
Additionally, would it be possible for you to share the configured SCB register values with me?
Thank you for your assistance.
Shubham
lokesh0806
Hi Shubham,
I am attaching the configuration files which we generated from EBtresos.
Can we connect over the teams call ? To understand the problem properly.
regards,
Lokesh
