Hi ,
Good day.
I have a questions about read blank work flash through SWD.
I found there is different behavior while CYT2B7xx/CYT4BBxx series read blank work flash.
For CYT4BB/BL series : it is able to read out the random (spurious) data from work flash.
For CYT2B7/BL series : it is unable to read out the random data, and it always shows ACK fault of SWD.
I want to know it is possible to set up CYT2B7's register to make the behavior is same as CY4BB series?
in other words, I hope CYT2B7/BL is able to be read random data if work flash is blank.
Thank you.
Jack
TRAVEO™ T2G
Hi Jack,
All devices will behave in similar manner. You can check if FLASHC.WORK_ECC_EN is set or not. Note that as said earlier, reading blank WorkFlash region will lead to ECC fault- so if the ECC check is disabled then fault is not generated- and this results in spurious data being read.
Ashish
Hi Jack,
It's not recommended to read blank region in WorkFlash- it may read spurious data and could lead to ECC fault. If you want to check if a region is blank or not, kindly perform a blank check using the BlankCheck api.
Ashish
Hi Ashish,
Thanks for your reply.
I know this information as you mention.
Because i face different behaviors on CYT2Bxx series and CYT4Bxxx series, so i'm asking whether a way makes the same behavior. If no, i just ignore it.
Thank you.
Jack
Hi Jack,
Ashish
Hi Ashish,
Thanks for your great support.
I will try to test it because I expect the behavior is same in TraveoII series.
Thank you.
Hi Ashish,
Update the status.
I read the register of FLASHC_FLASH_CTL, and the both series is different.
CYT2B7/2BL=> 0x00110000
CYT4BB/4BF => 0x01010000
This is why the behavior is different.
Then, i have set the value 0x01010000 to CTY2Bxxx series to make the behavior is same as CYT4Bxxx series.
Jack
