I'm refer to the programming spec(002-22035 Rev. *B) of Traveo II to develop the programming algo.
Regarding to the CallSromApi subroutine, there is the description.
// Enable the notification interrupt of IPC_INTR_STRUCT[0](CM0+) for IPC_STRUCT[IpcId]
WriteIO IPC_INTR_STRUCT + IPC_INTR_STRUCT_INTR_IPC_MASK_OFFSET, 1 << (16 + 2));
May I know what definition is for IPC_INTR_STRUCT_INTR_IPC_MASK_OFFSET?
I'm not it is typo or not. Thank you.
32-bit
Hi ,
The definition of IPC_INTR_STRUCT_INTR_IPC_MASK_OFFSET appears to be missing in programming spec document, but the comment above the line mentions "Enable the notification interrupt of IPC_INTR_STRUCT[0](CM0+) for IPC_STRUCT[IpcId]" . So, you can refer the Register TRM of the target device , under IPC_INTR_STRUCT0_INTR_MASK (refer snapshot from TVII-BE-2M Register TRM below) . Since the parameter being passed is IPC_INTR_STRUCT + IPC_INTR_STRUCT_INTR_IPC_MASK_OFFSET, so you can subtract the IPC_INTR_STRUCT value (0x40221000) to get the offset value (which should be 0x08 here).
Ashish
