Protocol error in arbitration layer detected
pdnr7
First like given First reply posted First question asked
While performing Deep sleep, before entering sleep Protocol error in arbitration layer detected bit in MTTCAN->IR register is reset, but after coming out of sleep this bit is set, what could be the possible issue in this case
Reza_A
100 replies posted 25 solutions authored 10 likes given
Hi @pdnr7,
Apologies for the delayed response.
Could you kindly refer to sub-section Power Down (Sleep Mode) in the CAN FD Controller section of your device's Architecture TRM? This sub-section provides the information on how to set your M_TTCAN channel into power down mode by configuring the Clock Stop Request bit (CANFDx_CTL.STOP_REQ). Please kindly follow the provided instruction on setting M_TTCAN channel into power down prior to entering DeepSleep and also how to leave the power down mode after coming out of DeepSleep.
I hope this helps.
Thank you.
Best regards.
Reza_A
Hi @pdnr7,
I will be checking this.
I will update this thread as soon as possible.
Thank you.
Best regards.
Reza_A
Hi @pdnr7,
I hope this helps.
Thank you.
Best regards.
pdnr7
Hi @Reza_A
Thanks for the response!!
I followed these steps in code as per the document:
1. Before entering Deep Sleep, Set the STOP_REQ bit
2. Wait for STOP_ACK to get Set.
3. Enter Deep Sleep.
4. After exiting sleep, Reset STOP_REQ bit
5. Wait for STOP_ACK to Reset
6. CCCR INIT bit to Reset from Ack.
But I am stuck at step 5,  STOP_ACK bit is not getting reset by the hardware. After which CAN also stops working.
For your reference I am using CANFD1, channel 0.
Thank you
Reza_A
Hi @pdnr7,
Thank you for the update!
Kindly refer to the AN220222 - Low-power mode procedure in TRAVEO™ T2G family, section 3.4. CAN wakeup operation. Infineon provides a SDL example code to enter and leave power down mode in the SDL additional code examples. Kindly find the link to download the SDL additional code example code below:
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.traveoiisampledriverlibrarycodeex
Kindly find the mentioned code example in AN220222_SysPM_DeepSleep -> 3.4_CAN_Wakeup.
If you haven't download SDL yet, kindly find the link to download SDL in the following. I believe it would be beneficial for you to understand the SDL-based APIs used in the example code above, and to test other T2G functionalities. You can compile your code using cmake, kindly follow the instruction provided in cmake -> CMake_Readme, in the Prerequisites section.
I hope this helps.
Best regards.
