pdnr7
5 sign-ins First like given First reply posted
While performing Deep sleep, before entering sleep Protocol error in arbitration layer detected bit in MTTCAN->IR register is reset, but after coming out of sleep this bit is set, what could be the possible issue in this case
Reza_A
250 sign-ins 50 likes received 50 solutions authored
Hi @pdnr7,
Apologies for the delayed response.
Could you kindly refer to sub-section Power Down (Sleep Mode) in the CAN FD Controller section of your device's Architecture TRM? This sub-section provides the information on how to set your M_TTCAN channel into power down mode by configuring the Clock Stop Request bit (CANFDx_CTL.STOP_REQ). Please kindly follow the provided instruction on setting M_TTCAN channel into power down prior to entering DeepSleep and also how to leave the power down mode after coming out of DeepSleep.
I hope this helps.
Thank you.
Best regards.
Reza_A
Hi @pdnr7,
I will be checking this.
I will update this thread as soon as possible.
Thank you.
Best regards.
Reza_A
Hi @pdnr7,
I hope this helps.
Thank you.
Best regards.
pdnr7
Hi @Reza_A
Thanks for the response!!
I followed these steps in code as per the document:
1. Before entering Deep Sleep, Set the STOP_REQ bit
2. Wait for STOP_ACK to get Set.
3. Enter Deep Sleep.
4. After exiting sleep, Reset STOP_REQ bit
5. Wait for STOP_ACK to Reset
6. CCCR INIT bit to Reset from Ack.
But I am stuck at step 5,  STOP_ACK bit is not getting reset by the hardware. After which CAN also stops working.
For your reference I am using CANFD1, channel 0.
Thank you
Reza_A
Hi @pdnr7,
Thank you for the update!
Kindly refer to the AN220222 - Low-power mode procedure in TRAVEO™ T2G family, section 3.4. CAN wakeup operation. Infineon provides a SDL example code to enter and leave power down mode in the SDL additional code examples. Kindly find the link to download the SDL additional code example code below:
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.traveoiisampledriverlibrarycodeex
Kindly find the mentioned code example in AN220222_SysPM_DeepSleep -> 3.4_CAN_Wakeup.
If you haven't download SDL yet, kindly find the link to download SDL in the following. I believe it would be beneficial for you to understand the SDL-based APIs used in the example code above, and to test other T2G functionalities. You can compile your code using cmake, kindly follow the instruction provided in cmake -> CMake_Readme, in the Prerequisites section.
I hope this helps.
Best regards.
