TRAVEO™ T2G Forum Discussions
Valer1
First question asked Welcome!
Please help to read full flash of S6J3001 (S6J3200) using Traveo Flash Memory Programmer V01.L03?
I know the pin-outs. But do not want to take the risk of erasing/overwriting the flash.
Please help with the step by step process - regarding Reset pin, MD pin, sequence of buttons in the Programmer and the range to select.
The diagram from the help file attached.
P.S. The manual for the Flash Memory Programmer V01.L03 does not specifically mention read only function. And it does not clearly outlines the sequence to get to read only of the full flash.
Ashish
25 likes received 50 solutions authored 100 replies posted
Hi ,
The details on Serial Programming can be found in the corresponding Series HW manual document- chapter-14 "Serial Programming". For device of S6J3200 series, the corresponding Series HW document can be found here:
https://www.infineon.com/dgdl/Infineon-32-bit_Microcontroller_Traveo_Family_S6J3200_Series_Hardware_...
Additionally , if you are using Cypress - "Flash Programmer for Traveo" software which is used for serial programming via uart , you may refer the user guide of the same (document number- 002-12509) for detailed explanation.
Ashish
Ashish
Hi ,
Ashish
