We need to design a microcontroller pcb, which works in a harsh environment ( a lot of vibration and temperature changes). So I selected two controllers (S6J33 and S6J32 series) for this design as a AEC-Q100 qualified, which are in stock at this movement.
These two microcontrollers are available to order, but the development kits are not in stock. I need your support about the development kit availability or the schematic diagram of the kit as a reference to start the design.
Actual requirement of the Microcontrollers are Memory >= 2MB, RAM 512kb and 80+ digital I/O.
S6j3xx is legacy Traveo-T1G series microcontrollers. If you need active support in the development, we would request you to consider Traveo-T2G series . They are also AEC-Q100 qualified microcontroller fit for automotive applications. Kindly refer this Appnote for all the available variants and its feature set in this series:
Also refer this page:
Ashish
Ashish
