MohamedGalal
5 sign-ins First question asked Welcome!
I would like to confirm the compatibility between the following:
Microcontroller: CYT2B95CACQ0AZEGS
Evaluation board: CYTVII-B-E-100-SO
Base board: CYTVII-B-E-BB
Also, would like to confirm that the winIDEA and Lauterbach debuggers with this evaluation board
Apurva_S
100 likes received 500 replies posted 250 solutions authored
Hi @MohamedGalal
Base boards can be used with all evaluation boards.
To check the compatibility between CYT2B95CACQ0AZEGS and CYTVII-B-E-100-SO, first thing to check would be the package. CYTVII-B-E-100-SO board has a socket for 100 pin LQFP package device. The selected device should be of the same package. Next you should also check the pin out of the device and the schematic of the evaluation board to ensure that signal routing is happening correctly.
Regarding winIDEA and Lauterbach debuggers compatibility, it works only on MCAL, and not for SDL.
Regards.
Apurva_S
Hi @MohamedGalal
Regards.
