Dmitriy_Chernov
Hello, I am trying to set up memory protection from external reading (via debugger) on CYT2B78CAB, but in the SDL there is no example of limiting external memory access. Can you have an example of how to do this?
Nambi
100 solutions authored 250 replies posted First like given
1. Could you check if "12.3. How do I perform Authenticated Debugging in CYTx devices?" in the below link applies to your requirement?
https://community.cypress.com/gfawx74859/attachments/gfawx74859/KnowledgeBaseArticles/6356/1/TRAVEO%...
2. You can also check if SMPU suits your requirement. An example for SMPU is available as a part of the SDL.
Best Regards.
Nambi
Best Regards.
