LPACTIVE, LPSLEEP mode in Traveo II (CYT2B95)
taegyunahn
Level 4
Level 4
Distributor
100 sign-ins 25 replies posted First comment on blog
Hello
I have reviewed the solution provided in the link below, but I have some additional questions.
link : https://community.infineon.com/t5/TRAVEO-T2G/Low-Power-Active-mode-in-Traveo-2-CYT2BL5CAS/td-p/39864...
I have confirmed that the section under the 'Device Power Modes' in the Architecture TRM, titled '17.2.1.1 Low-Power Profiles - LPACTIVE and LPSLEEP', contains the following information regarding Examples.
Q1 > If the power consumption is reduced by turning off FLL through software settings and configurations in the Active mode(ECO, PLL/FLL on), can it be referred to as LPACTIVE mode?
Q2> Is it correct that the transition from Active mode to LPACTIVE mode is not accomplished by changing specific registers?
Thank you.
MSV
Kavya_B
10 likes given 25 solutions authored 5 likes given
Hello @taegyunahn ,
Below are the answers to your questions:
1) Yes
2) Yes
Kavya
Kavya_B
Hello @taegyunahn ,
1) Yes
2) Yes
Kavya
