Nov 19, 2021
01:41 AM
Nov 19, 2021
01:41 AM
Hi All,
Is there any method using which we can run only CM4 core in Traveo II CYT2BL5Cxx board.
Currently the CM0+ code is flashed using the .out file from the sample driver.
User code of CM0+ should not run. After power up the CM4 core alone should run.
I went through the TRM and found there is a way for this using SFLASH_SINGLE_CORE_WOUND memory.
But I couldn't find the address. Can anyone tell this configuration is supported for my controller.
Labels
