Jackson_hwang
5 replies posted 5 questions asked 25 sign-ins
The CANFD driver is provided in the TRAVEO T2G Sample Driver Library files. Is there also a Classic CAN driver files?
T2G_Sample_Driver_Library_7.8.0\common\src\drivers\canfd
- cy_canfd.c
- cy_canfd.h
Reza_A
25 solutions authored 10 likes given 50 replies posted
Hi @Jackson_hwang,
You can use the CANFD driver for Classic CAN protocol.
Kindly check the Classic CAN code example in the following directory:
examples -> canfd -> Classic_CAN
I hope this helps.
Thank you.
Best regards.
Reza_A
Hi @Jackson_hwang,
I hope this helps.
Thank you.
Best regards.
