MohamedGalal
5 sign-ins First question asked Welcome!
We are trying to configure the intterupts for the CYT2B98 controller using a received AUTOSAR tresos MCAL package.
WE configured the OsIsr container inside the OS package (which enables us to configure the CPU interrupt only), but it seems that we need to map the System interrupts to the CPU interrupts. We looked inside the sample library and found that this mapping is done through the 'cy_interrupt_map.c' file. The question is, do we need to implement the same file as a CDD inside our project or there is an AUTOSAR module inside the package should take care of this?
KB
10 solutions authored 50 sign-ins 25 replies posted
Hi MohammedGalal,
Since the thread is related to MCAL,  I have created the case in MyCases on your behalf.
We will discuss further over MyCases.
Thank you.
KB
