Jackson_hwang
5 replies posted 5 questions asked 25 sign-ins
I am trying to drive a motor with PWM using TRAVEO T2G CYT2B7's MCU, but I have a question.
1. What is the difference between TCPWM for motor control and general TCPWM?
2. I want to use Full Bridge (H-Bridge) to control motors (forward, reverse, speed control, etc.).   Should I use a dedicated TCPWM for motor control or can I use a general TCPWM?
3. Or is it possible to use two (High Side) motor control TCPWMs and two (Low Side) general TCPWMs?
4. Are there any precautions when controlling H-Bridge motors?
Reza_A
25 solutions authored 10 likes given 50 replies posted
Hi @Jackson_hwang,
We have an article about TCPWM 16-bit Motor Control available in following link, it describes the differences between TCPWM 16-bit Motor Control and other TCPWM types, as shown below:
To drive a DC motor with H-bridge configuration, you could use general TCPWM since you wouldn't be needing the additional functionalities that Advanced Motor Control provides.
As a precaution, you would already know this, but please make sure that you don't turn on the high-side and low-side switches of the same leg (A' and B or A and B') at the same time to avoid short circuiting.
I hope this helps.
Best regards.
Reza_A
Hi @Jackson_hwang,
I hope this helps.
Best regards.
Thank you for your kind reply.
