There seems to be a difference in the initial state of the input buffer between the following two. Which one is correct?
2.1. What is the status of unused GPIO pins?
The default mode is High-Z, input buffer is enabled, and no internal pull-up/down resister connected.
https://community.infineon.com/t5/Knowledge-Base-Articles/Traveo-II-Automotive-Body-Controller-FAQ-G...
T2G Body Entry Arch TRM (002-19314 Rev. *H)
22.6.1 Drive Modes -> High-Impedance
High-impedance drive mode with input buffer disabled is also the default pin reset state.
TRAVEO™ T2G
The correct info is :
Also, we will update the same information in below mentioned KBA.
Thank you.
Apurva
Thank you.
Apurva
Hello Kako_4074056,
for your reference and understanding of KumarAP's answer please have a look at the T2G's register TRM, chapter GPIO, register GPIO_PRT_CFG. After Reset the default value of this register ist 0x0. This means thal all the bits IN_ENx are cleared to zero, too.
When IN_ENx == 0 then the input buffer is disabled. So, as KumarAP already pointed out, the default pin reset state is high-impedance with input buffer disabled.
