I am using Traveo II Family Entry Starter Kit (CYT2B75CADES).
I have tried to flash and debug Firmware from IAR (ARM 9.20.4), but I got the problem as below:
Failed to load the CPU core driver Session aborted!
I have followed all guide from these links (use SWD CMSIS DAP, upgrade KitProg3)
But the problem can't be solved.
Please check and help me to solve this problem.
TRAVEO™ T2G
Hi @txcao ,
Please run below mentioned commands in sequence using "Auto Flash Utility" :
1. to erase :
openocd -s ../scripts -f interface/kitprog3.cfg -c "transport select swd" -f target/traveo2_1m_a0.cfg -c "init; reset init; flash erase_sector 0 0 last; shutdown"
2. to program :
openocd -s ../scripts -f interface/kitprog3.cfg -f target/traveo2_1m_a0.cfg -c "program <elf/srec/hex file path> 0x0 verify exit"
Thank you.
Hi @txcao ,
Could you please try to erase and program the chip using "Auto Flash Utility".
Thank you.
Hello Kumar,
Error: DAP 'traveo2.cpu' initialization failed (check connection, power, etc.)
Please help me to check it.
Hi @txcao ,
1. to erase :
2. to program :
Thank you.
