Dears,
According to document AN227076, if users want to update APP, they need to customize Flash Loader by themselves. CAN we provide Flash Loader sample code based on CAN interface and the source code of PC's APP?
- Flash loader
Hi Jack_Jiang,
The Traveo-II device contains internal bootloader that already supports CAN interface , The AppNote AN227076 (https://www.infineon.com/dgdl/Infineon-Traveo_II_Bootloader-ApplicationNotes-v01_00-EN.pdf?fileId=55...) describes in details on how to implement this (i.e. how to update your application over CAN). As far as flashloader part is concerned , I think it should be developed by the user as per the use case- but I am checking if there is any reference to share with you.
Ashish
Hi Jack_Jiang,
Ashish
Hi Jack_Jiang,
As said earlier, you may need to develop your own flashloader as per your use case, unfortunately there is no customer-shareable reference to share with you.
Ashish
