Sep 25, 2021
04:24 AM
Sep 25, 2021
04:24 AM
I am getting the error as in the image attached,using Miniprog4 for flashing(CYT2B98CA) it not sure why i am getting this error,It will be great if anyone can support to fix the error.
Labels
11:22 PM
Sep 28, 2021
11:22 PM
Hi ,
Can you please attach the full log file (along with what command you are using to flash)? Also, are you using Cypress AutoFlash utility to program? Also it appears to be writing memory at SRAM reserved region at 0x08000000 which is not accessible to user code , so this may be cause of error, but please give the full log to understand issue better.
Ashish
