Hi All,
What's the difference between Body High and Body Entry Traveo II chips.
Is CYT2BL5 is a Body entry / Body High Chip?
If any document provides this information can you post that also.
- traveo ii
Hi @Venkatesh
This nomenclature is based on the target application (entry level body control units vs high end body control/gateway etc), and the difference is mainly between the Application core (CM4 for body entry, CM7 for body high), beside other differences in memory and peripherals. You can refer following document for differences between body-high and body entry.
CYT2Bx is Body-entry product, with CM0+ and CM4 cores, so your device is body entry. Where as for body-high, it would be CYT3Bx/CYT4Bx . It has CM0+ and 1 or 2 CM7 cores.
Ashish
Hi @Venkatesh
Ashish
