Nov 11, 2021
08:35 PM
Nov 11, 2021
08:35 PM
Dear supporters,
I get a Hardfault When I enable work flash ecc. Could you give me some supports?
Labels
Automotive Traveo_II
09:50 PM
Nov 15, 2021
09:50 PM
Hi Terry,
Please initialize flash before using it.
Cy_FlashInit(false);
Finn
12:23 AM
Nov 12, 2021
12:23 AM
Hi Terry,
As it shows, a precise data access error has occurred. What is the last piece of code you have run before this error occurred? Where are you trying to access to?
It would be easier to find the problem if you provide your codes.
Finn
Nov 14, 2021
04:55 PM
Nov 14, 2021
04:55 PM
Hi yanf,
Thanks!
The follow picture is this part code. It's stranger If I WORK_ECC_EN, then get the Hardfault.
Nov 15, 2021
09:50 PM
Nov 15, 2021
09:50 PM
Hi Terry,
Finn
