Checksum
meriam
I am trying to flash a hex file generated by makefile with cypress autoflash utility.
But I always get an error with checksum.
I am using traveo ii cyt2b75cades starter kit board.
I have attached my hex file and linkerscript.
thank you for your help,
KumarAP
250 sign-ins 50 solutions authored 100 replies posted
I have tried flashing the attached hex file (present inside the "LED_blink_onTraveo-II_starter_kit_hex_file" zip file and generated by using IAR IDE) using Cypress Auto Flash Utility 1.1 and able to successfully flash the program using below command on Traveo-II cyt2b75cades starter kit board :
command : openocd.exe -s ../scripts -f interface/kitprog3.cfg -f target/traveo2_1m_a0.cfg -c "program C:/cm0plus.hex verify reset; exit"
Output behavior on board : LED1 blinks with 100ms delay.
Please try above on your end, and if still issue persist, Please share the command which you tried.
Also Please refer section 5.3 of "Traveo II Automotive Body Controller - FAQ – IDE - KBA232509" document and Cypress Auto Flash Utility user guide.
KBA link : https://community.infineon.com/t5/Knowledge-Base-Articles/Traveo-II-Automotive-Body-Controller-FAQ-I...
One more observation is, sflash and sflash_alt address ranges are not correct in the shared linker file (linker_directives.ld file). Please check once(Figure 4-1 CYT2B7 address map) in CYT2B7 datasheet (CYT2B7_data_sheet_link ).
Thanks & Regards,
Apurva
KumarAP
Thanks & Regards,
Apurva
meriam
Hello Apurva,
I know that the hex files generated by IAR works amd flash into the board with cypress autoflash utility.
But, what i am trying to do is use a makefile, generate hex and flash with cypress autoflash.
for that, i created the makefile, the linker, used cygwin for make, but the hex generated didnt work.
i keep getting the checksum error.
any idea how i can solve this problem?
thanks,
JJack
Level 5
Level 5
Associated Partner - Distributor Rutronik
5 questions asked 25 likes received 100 sign-ins
Hi meriam,
I loaded your hex-file into the hex-viewer of JFLASH from Segger. It turns out that in your hex-file data is placed in two regions:
From address 0x08020020 to 0x08020048F and
from address 0x10110000 to 0x10110443.
Comparison with the memory map of CYT2B75 shows that both regions are "reserved" and possibly may not contain memory at all.
I am not familiar with the gcc linker commands. But it seems the linker places your code at the wrong addresses.
Example screenshot from JFLASH loaded with blinkingLed.hex
meriam
I updated the linker and the makefile (not sure), generated a new hex and build folder, please find it attached.
with this hex, I dont have any errors with autoflash utility but the led doesnt blink.
Do you have any idea on this?
thanks,
KumarAP
Can you try changing LED Port, Pin, and pin_mux configuration in application code(main_cm0plus.c file) as per Traveo-II cyt2b75cades starter kit board.
For LED 1, use below configuration :
#define ledport              GPIO_PRT19
#define ledpin                0
#define ledmux              P19_0_GPIO
Also please refer the below document :
https://www.infineon.com/dgdl/Infineon-Traveo_II_Microcontroller_for_Body_Starter_kit_User_Guide-Use...
Thanks & Regards,
Apurva
meriam
Hi KumarAP,
I am using an external led, thats why i have those definitions
thanks,
KumarAP
Hi Meriam,
Can you Please try for on-board LEDs once (mentioned in last comment) and share the result ?
or try to flash attached hex file.
meriam
the hex works, and the led blinks.
But the one with the makefile and linker doesnt, even with no errors.
I also saw this about the reset handler, could this be the problem?, or is the linker im using faulty?
thanks,
JJack
Level 5
Level 5
I think your makefile/project is missing the highlighted sources:
meriam
in the buid folder it generated .s file.
could you please explain a litlle further?
i dont intend to use any other IAR files.
thanks,
KumarAP
In project/makefile, startup related file is not included. Please include the missing files(highlighted above) in project folder.
I would suggest you to refer the latest SDL 7.5 for the linker reference, and also it has CMake support so you can refer it for your reference.
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.traveoiisampledriverlibraryutil?utm_source=...
meriam
I checked, and there isnt any !? It s only pin mux and trigger mux configurations, nothing for CMAKE.
Do you think it would be possible to generate a flashable hex file from a makefile using IAR files (startup , .c ,.h,..) ?
Do you have any example project with that ?
Would you recommend using CMake instead of makefiles?
I have also added the highlighted files you told me about, but it still doesnt work. Could you please review my makefile?
Thank you so much!
KumarAP
Hi ,
I would suggest you to refer the latest SDL 7.5 for CMake support and you can refer it for your reference. Download and install SDL, then go through the "CMake_Readme.md" file (path -->> T2G_Sample_Driver_Library_7.5.0\cmake) and "CMakeLists" file (path -->> T2G_Sample_Driver_Library_7.5.0) for configuration.
Try the mentioned steps as per "CMake_Readme.md" file.
Link for latest SDL : https://softwaretools.infineon.com/tools/com.ifx.tb.tool.traveoiisampledriverlibraryutil?utm_source=...
cmake related query is discussed here : https://community.infineon.com/t5/TRAVEO-T2G/cmake-traveo-starter-kit/td-p/356042
Thank you.
Apurva
