Bhagyalakshmi
10 sign-ins First like given 5 sign-ins
i want to configure CANFD for 8MBPS baudrate could u please helpme out how to configure ? i have configured for 2mbps it was working fine.but not able to configure for 8mbps there is a sync issue between canoe and controller i am getting Canfd Tx error. is there any data sheet for canfd baudrate calculator. please support. and also we are using TJA1463A transciver it will support upto 8mpbs baudrate. and the clock frequency is 80mhz
Reza_A
25 solutions authored 10 likes given 50 replies posted
Hi @Bhagyalakshmi,
I will take a look at this and will update you as soon as possible.
Thank you.
Best regards.
Reza_A
Hi @Bhagyalakshmi,
Apologies, there is no CANFD Baud rate calculator for T2G devices.
For hints on how to configure the CANFD, kindly refer to the AN220278 - CAN FD usage in TRAVEO™ T2G family sub-section 2.2.2 Bit Timing, and please check out the CANFD code example available in the SDL. If the issue persists, please provide your current CANFD configurations and the full error details .
Thank you.
Best regards.
