Bhagyalakshmi
10 sign-ins First like given 5 sign-ins
How do I find the time information about the CAN message received, that is, at what time was each CAN message received?
Reza_A
100 replies posted 25 solutions authored 10 likes given
Hi @Bhagyalakshmi,
This is a screen capture from the Architecture TRM.
Please make sure that you have enabled and configured timestamp counter in the CANFDx_TS_CTL field, and have configured the timestamp select bit in CANFDx_CHy_TSCC to select the global timestamp counter.
Kindly could refer to 23.2.2. Timestamp Generation in the Architecture TRM to read on how to enable the timestamp generation and where the counter value is stored.
I hope this helps.
Thank you.
Best regards.
Reza_A
Hi @Bhagyalakshmi,
I hope this helps.
Thank you.
Best regards.
