CYT4BF8CED
xu
First like given First reply posted 10 sign-ins
I'm going to program the SFLASH region. But I'm not sure if I can Erase it using the Erase sector function.
xu
Kavya_B
10 likes given 25 solutions authored 5 likes given
Hello @xu ,
You cannot use 'EraseSector' system call to erase SFlash. You need to use 'WriteRow' system call to program SFlash.
There are some restrictions you need to be aware of while programming SFlash. The system calls which one uses for programming SFlash are different than that for code flash / work flash in Traveo II. User cannot program all the sections of SFlash. Only certain sections of the SFlash will be allowed to program by the user through WriteRow system call. Please refer to sub-section ' WriteRow' under chapter 'Nonvolatile Memory Programming' in Architecture TRM (Document No. 002-24401) for more details.
Kavya
Kavya_B
Hello @xu ,
Kavya
xu
Hello@Kavya ,
What is the minimum write unit of SFLASH region?Is it 0x200 bytes?
xu
Kavya_B
Hello @xu ,
Yes, you are right.
Kavya
