- Email to a Friend
Can I refer to the programming spec(002-22035 Rev. *B) of Traveo II to program chip CYT4BF8CED?
xu
- Email to a Friend
Hi @xu ,
Please follow the below steps for joining to MyICP:
1. Register for myInfineon using below link.
Link : https://www.infineon.com/cms/en/product/microcontroller/#register
2. For Traveo documentation, please email to Traveo@infineon.com
3. You will receive a confirmation which explains how to use your new access.
4. After getting the access to MyICP, you will get the programming spec( i.e. 002-22035_0C_Programming_Specifications) by following the mentioned below path :
(TRAVEO-Documentation -->> Traveo II --> Traveo II Body --> Programming Specs -->> 002-22035_0C_Programming_Specifications)
or you can access below link also :
Link for programming spec : https://myicp.infineon.com/sites/TRAVEODocumentation/SitePages/default.aspx?RootFolder=%2Fsites%2FTR...}
- Email to a Friend
Hello @xu ,
Yes, you can refer the latest revision of the programming spec( i.e. 002-22035_0C_Programming_Specifications) to program the TRAVEO™ II MCU family.
You will find this document on MyICP .
You can join MyICP by following the steps mentioned on this link - https://www.infineon.com/cms/en/product/microcontroller/#!details
Thank you.
BR.
- Email to a Friend
I have joined MyICP, but I can't get it.
Thank you.
xu
- Email to a Friend
Hi @xu ,
