CYT3DLABHAES BSDL File
Christian1980
Hello
i am looking for the BSDL File
Hello @Christian1980
Please find the follwing path for the file
Traveo 2>Traveo 2 cluster>BSDL
In above mentioned path, there one folder called BSDL where you will find all the files
Note: To access these files NDA is required.
Thanks & Regards
Abhishek Kulkarni
abhikul
10 solutions authored 25 replies posted First like received
You can download the BSDL file for your device from myicp portal.
If you don't have access for the portal, please register yourself on the portal to get access to all the files
I have attached the link for the portal:
https://myicp.infineon.com/SitePages/Portal.aspx
Thanks & Regards
Abhishek Kulkarni
Christian1980
Thanks for the answer.
I have access here.
but can't find the BSDL file.
Thanks & Regards
Abhishek Kulkarni
