Dears.
I'm looking for CYT2BL/CYT3BB/CYT4BB Pin Matrix Excel Sheet.
Could you tell us where I download them ?
Thanks and best regards,
Kevin Han.
TRAVEO™ T2G
- PIN MATRIX
Hi Kevin,
Since the datasheet already has all the information (table 11-1 and 12-1) , if you want you can just create an excel sheet from there (we can verify it if you need that). It's only matter of format (excel vs pdf)!
Kind Regards,
Ashish
Hi Kevin,
The requested information (Pin assignment with alternate functions) is available in device datasheet (pdf format), you can refer that document . There is no excel sheet available for download, may I know why that's needed?
Ashish
Hello Ashish.
Thank you for your comment.
The reason why i asked is that car OEM or Tier 1 development company need them which are guaranteed by Infineon. You are right but using only Pin matrix that are represented in Datasheet looks so inconvenient because these customers are getting through several time sensitive projects with T2G.
Pin assignment excel tool for T2G 1M, 2M as the following is available but i'm sorry i heard that is not available for CYT2BL/CYT3BB/CYT4BB.
Kevin Han.
Hi Kevin,
Kind Regards,
Ashish
Hello Ashish.
Thank you for your help. I'll contact with you again when it's ready.
Kevin Han.
