- Email to a Friend
Tx is OK. the slave(PC) could get the Tx data。
but Rx is NG. cannot receive data. and the interrupt funciton do not run (set the break point,but not stop at it ).
- Email to a Friend
Please elaborate a little more on your setup. Are you using any of the development boards or your own custom board?
Also, are you using the SDL? If yes, which version? Are you using the example as is or have you made any modifications?
Regards.
- Email to a Friend
Regards.
- Email to a Friend
Thank you.
i used startkit from T2G_Sample_Driver_Library_7.5.0\tviibe1m\tools\iar\flash\tviibe1m_flash_cm4_mc_template.eww。
because want to use Can, i rewrite the main(), to call ClassicCANInit()。
then,I tried the tx by Cy_CANFD_UpdateAndTransmitMsgBuffer() was OK.
Rx is via Interrupt that calls Cy_CANFD_IrqHandler()。When i send data to board via Can, but didnot find Cy_CANFD_IrqHandler() runned。
