TRAVEO™ T2G Forum Discussions
LeJe_4431886
Hi
     I am using CYT2B77CABES mcu. Now I have the Traveo II MCU Programming Specifications(002-22035) document. Is the lastest revision document is *A(issue date: 09/27/18) ?
     Because I found something wrong in this version of document. I read the Traveo II MCU Programming Specifications. I can not find the Macro of “IPC_INTR_STRUCT_INTR_IPC_MASK_OFFSET” in the document. But in the CallSromApi API use this macro. Can you tell me the value about this macro?
     Can you give me the lastest vesion of Traveo II MCU Programming Specifications(002-22035) document?
Have a good day
Jerry
002-22035,rev.*A is the latest one.
For the information of that Macro, please kindly check TVII TRM.
Amy Wang
HongyanW_86
100 solutions authored 100 replies posted 50 solutions authored
This topic is not suitable to be discussed here in community. Please kindly contact Cypress sales team or distributors for your request.
Amy
Hi Amy
     Can you just tell me does it have the lastest version? If it is not the lastest version, I will contact the Cypress sales myself.
Have a nice day
Jerry
Amy Wang
