[CYT2B75] after full chip erase, SWD cannot be connected
machengyan
First reply posted First like given First question asked
The chip model is [CYT2B75CADES], after full chip erase, SWD cannot be connected,
I think the bootloader is damaged, is there any way to rebuild it?
Apurva_S
100 likes received 500 replies posted 250 solutions authored
Hi @machengyan
Could you please provide more details about the issue? Please tell us the exact steps you followed, and why do you suspect that the bootloader is damaged?
You can go through this application note that we have on T2G Bootloader - https://www.infineon.com/dgdl/Infineon-Traveo_II_Bootloader-ApplicationNotes-v01_00-EN.pdf?fileId=55...
Regards.
Apurva_S
Hi @machengyan
Regards.
thanks for your response
my steps:Erase flash in IAR
Project->download->Erase memory   and OK
After that ,SWD cannot be connected.
Referenced data sheet:Infineon-Traveo_II_CYT2B7_Series_Data_Sheet-DataSheet-v01_00-EN.pdf
And I think this is not implemented.   Because 0x1700 2000 should have been erased too.
Apurva_S
Hi @machengyan
Can you tell the exact memory locations that you erased? Did it also include sflash memory locations? If yes, please tell the range.
Can you try to program your device using Auto Flash Utility and let us know if it works?
Regards.
