When I used IAR to download the program to the development board, "Failed connect to CPU" kept appearing, I could not download the program, what should I do?
Hi @Beautr
Please tell us more about the setup.
- Which development board are you using?
- Which SDL version are you using?
- Please tell the exact steps to reproduce the issue. Are you using the default projects in SDL or have you modified it?
- Did you try to program the device using "Auto Flash Utility"? If not, can you try that and see if it works?
Regards.
Hi @Apurva_S
The development board I used was TRAVEO II ENTRY FAMILY STARTER KIT,The chip used is CYT2B75CADES.
The SDL version is T2G_Sample_Driver_Library_7.5.0.
This problem was prompted when I downloaded the project after modifying it, and the original project of the development board was not executed.
what is "Auto Flash Utility"?Where should I go to get it?
Hi @Beautr
You can find the download link for Auto Flash Utility on this thread - https://community.infineon.com/t5/TRAVEO-T2G/Auto-Flash-Utility-download-link/td-p/353345
After installation, you will find the documentation for it in the installation path.
Regards.
