rbs2kor
First reply posted First like given First question asked
Hi, We are working on a project using Traveo T2G CYT4BF and CPU utilization is very high. We have enabled Icache.
1. We wanted to understand how to optimally use ITCM and DTCM(CM7_0 and CM7_1).
2. Does using ITCM when ICache is enabled will provide any CPU performance benefits ?
3. How to optimally design the clock frequencies for optimized CPU performance ? Do we use maximum allowed clock frequency for CPU and memory ? Or is there a way to calculate clock frequencies ?
Already referred to the following resource.
TRAVEO™ T2G MCU: CPU performance improvement techn... - Infineon Developer Community
Reza_A
25 solutions authored 10 likes given 50 replies posted
Hi @rbs2kor,
1. As mentioned in KBA236986, the optimal use of TCM memories is to store the stack DTCM and the most frequently accessed functions could be executed from ITCM. There is no such generic recommendation from our side for which content can be moved to ITCM. But you can try to move vector table to ITCM using linker attributes. Typically one would probably link frequently executed code.
2. It is not guaranteed that using ITCM while enabling I-cache will increase the performance.
3. As mentioned in KBA236986 also, operate CM7 at its maximum allowed frequency for the best CPU performance. Kindly check the device datasheet for the maximum frequency of CLK_FAST.
Reza_A
Hi @rbs2kor,
rbs2kor
Thanks a lot for quick response.
